iPhone data recovery ubuntu installation safe?
Asked By 100 points N/A Posted on -
Have anyone of you tried doing an IPhone data recovery Ubuntu setup? I've tried recovering in Windows installation several times. I read an article about recovery in Ubuntu and it seems simpler. Any inputs would be a great help. I want to know your experiences before trying it.
Thanks
Answered By 0 points N/A #190539
Hi, Martin,
I wouldn't suggest that you tinker with your phone using those setups, especially when you are not an experienced user of these techniques.
Most people are not aware that when you plug in your iPhones to your computer, while syncing with iTunes, it creates a backup file. The only problem is, there is no way in viewing or getting those files because they are encrypted. But That is no longer a problem anymore. These files can be retrieved by using a special program recently developed to view and extract data from those files. The program is called Wondershare Dr. Fone.  There is a free trial available, where in you can only view files but not extract them. It's a bit pricey when you have to buy it but it is worth the purchase since you will not have to tinker with your precious device.
All those files that you have on your phone, may it be Videos, images, text messages, and so on, everything can be retrieved with this rescue tool. Even if your phone was stolen or broken, files can still be retrieved just as long as you have backed up your data.
