Hi there,
I have this error on my iPhone when I want to install a fully compatible application. During the install this error appeared and I have to close the market and try to install the app again. Can anyone help me please with this error ?
Thank you!
Error
This application will not work on your device(8002)
OK
iPhone fails to install the application from market
Hello Charles,
The application can be side loaded onto your iPhone. If there is an APK file on your computer, the excellent Agile applications can be applied in order to up load the market applications onto your iPhone. This can be done without connecting your iPhone to the computer.
In Android and iOS Smartphones and devices, before you can install an application, you have to check first if the app supports your current firmware or your device’s operating system. If you have an iPhone and you want to install the Nok Nok Passport app, check the specification of the app on the download page to verify if your phone’s current iOS is supported.
The latest version at the moment, Nok Nok Passport 5.2 requires iOS 8.1 and higher and supports iPhone, iPad, and iPod touch. For Android, Nok Nok Passport 5.2.0 requires Android 4.4 KitKat and higher. If you have an iOS device and your current iOS version is supported but you cannot install the app, your device is probably not supported.
Nok Nok Passport is an authentication app that supports the UAF protocol or Universal Authentication Framework from FIDO Alliance. It allows you to use out-of-band authentication to authenticate selected websites on a desktop or laptop computer.
