I have an iPhone firmware of which I want to downgrade, before doing so I have to edit the list of IP addresses of which is stored in a file name “hosts”.
I can access the file but I can’t edit it. It displays an error message: “contact administrator” but I am responsible for administrative and backup operations.
Kindly help me where I go wrong?
IPhone firmware downgrade with errors
Hi Daniel,
I suggest you to get shsh blob using the tiny umbrella to be able to solve your issue. Please follow the procedures below to:
Download tinyumbrella,. You can download it depending on your OS
Download it on this link http://blog.firmwareumbrella.com
Install tinyumbrella
Connect your iPhone into your computer
Click save shsh after launching tinyumbrella
Wait until it successfully download shsh blobs
After saving it, go to log tab and then start tss server
Close iTunes
Open https://www.apple.com/
You can now launch iTunes
Downgrade your firmware
I hope it helps.
Zorian
You need to get shsh blob to solve this problem. To get shsh blob, at first you need to download it by using tiny umbrella. To get shsh blob by using tiny umbrella, you need follow this following steps:
1. Connect your iPhone via USB cable in your computer.
2. Open tiny umbrella and then click on the button named Save SHSH.
3. Open the Log tab and then click on the Start TSS Server button.
4. Now you will see this two following lines:
TSS Server Started!
TSS Accepting connections….
5. Now open https://www.apple.com/ from your browser.
6. After that this downgrade your iPhone firmware.
Thanks
