pulok79
Posted on - 05/11/2012
what kind of software has been used for this kind of protection and how it works?
IPhone saved a corning factory
Dear Pulok,
You want to know about iphone software, which can save something. There was a news published that iphone saved a corning factory. There are several types of software which helps in protection.
Iphone can’t do anything itself, it needs to operate by someone. That was occurred when iphone saved a corning factory.
There are many software’s are found in the iphone market as like android market. You can download that software from that website.
Software will give you tips in different condition to help you. You need to follow those tips. That’s it.
I hope you will get your answer from here.
Thank you.
