Hello Guys,
How to enable iPhone to smart share LG Smart TV, so that I can instantly share my iTunes music and movies with my LG Smart TV. Do I need to have any separate application for that in my iPhone, Please guide me to enable my iPhone to smart share with LG Smart TV.
Freddie C Slater
IPhone to smart share LG Smart TV
Hi !
First make sure that your TV can run a screen mirroring, and also check if IPhone can run it. Follow the steps to make a screen mirrorin between your phone and TV.
1) Go Menu on your TV remote => go to Network => All Share Settings => go to Screen Mirroring. Your TV will start to search for connection.
2) Make the same settings to your IPhone and they will connect automatically via Wi-fi.
3)Also you can try to screen mirroring with a software called Dongle Screen Mirroring. You can make these connections you will have to make sure that your TV has a HDMI port with an wireless.
