IPhone update delivers message to family members.
I really don't know what's actually going on. Two member, brother and mother, from my family have updated their iOS and they receive the message which I must be receiving. I don't know if this is an update issue but this all happened after the updates last week. How can I fix this?
Answered By 590495 points N/A #192937
If both your mother and brother received the message after they have updated their iOS device and you didn’t, then maybe you haven’t updated yet your device. Try updating your iPhone to the latest iOS and then see if you will also receive the same message. The best way to update your phone is to use iTunes because not all updates are available via OTA or over-the-air.
Install the latest iTunes if you haven’t updated it yet. Visit Download Latest iTunes to download the latest version and then install it on your computer. After that, connect your phone to your computer via USB cable then start iTunes. Check for update and then install it. Once the phone is updated, wait for the message to arrive.
If you didn’t received a message maybe after a day, try restarting your phone and see what happens.
