gipe cody
Posted on - 10/04/2012
I have heard that one can use iphoto and imovie apps as a pic editor and transforming pictures into a movie respectively, i can edit the photos but i have no idea on how to turn them into a movie using imovie.
Some help.
IPhoto, iMovie as pic editor and transforming pictures into movie
There are many ways to import and export photos. The easiest way to bring in photos and music into iMovie is from iPhoto and iTunes is given down:
Firstly, you need to open iMovie and then, you need to click on the button which seems like a music note, middle computer screen and on the right hand side.
When you click on the button, you will open a list of all saved music files on your computer. When you have clicked on the next button which looks like a camera is a picture importing button.
You also can check the tutorials:
Cheers.
This is the same as with creating a slideshow with sets of images but the only difference here is that the final output is in video format and setting each image with a specific duration to display to simulate every scene of the movie. iMovie is an application from Apple that will help you turn your home videos into your all-time favorite films and share them with everyone.
iMovie puts all your videos in one place so you can browse and find them easily. This saves you time searching for files in not so sure folder locations. It also features a drag-and-drop moviemaking where you can simply drag a favorite clip on to your project, drag titles and transitions, add music and or photos. It also helps you fix shaky videos using the program’s video stabilization which analyzes how much your camera was moving and then automatically reduces shake. To know more about this, you may visit Apple | iLife ’11 | iMovie ’11.
