Ipod smart data failure error occurred.
Hello Experts,
I got my iPad with me for almost 1 year and when turning on my iPad there is an error that occurs. IPods smart data failure error occurred. What is this error means and what are the possible fixes or solution for this kind of error problem? I know you can help me or give me some tips on how to resolve this issue.
Thank you.
Best Answer by Mabel Gia
Answered By 5 points N/A #180829
This issue may happen due to some files of your iPod got infected Trojan or virus. To fix this issue, Connect iPod to pc in data storage mode. Now open cmd (Command prompt) and format using cmd. (as per below)
Then scan with this device using good antivirus software. Now add your audio files or other data to your iPod but make sure these files are not infected with virus.
Answered By 0 points N/A #180828
Most errors occur when the File system is corrupt or during a restore session that didn't complete fully. There are a number of solutions available you can try on to recover your iPod from smart data error. You can use Disk utility if you have a Mac or through Windows PC restore through iTunes which re-formats the iPod.
  1. Disk utility you can follow this easy steps, Disk utility > First Aid > Repair or Disk utility > erase.
  2. On Windows you can reset manually or through iTunes which will be like disk repair . To manually reset your iPod, Hold & press the Menu button& the center button together simultaneously for a minute until the Apple Logo comes on. Wait until reset process is complete & try to see if the error has been resolved.
  3. To reset through iTunes, Open iTunes> Connect your iPod>Select iPod source when it appears after connecting > Click on Restore button. A progress bar appears showing the various stages of the restore process.After restoration is complete, iTunes set up assistant appears which will guide you in choosing new settings for your iPod.
