rumana3265
Posted on - 09/15/2011
Hi I have a iPad and i want to update some software on my iPad. When i try it, i see this error message on screen.Error message is
"The iPod software update server could not be contacted.Make sure your network setting are correct and your network".
Why i see this error message?Every time i see it when i update software.I need help for solve this problem.Please everybody help me to solve this problem.I think that someone will be help me.Thank you
IPod software update server problem
Greetings..
I just experience this trying to update my ipod and this can be because the servers are swamped or because there are network problems somewhere in the great internet sky or your internet connection is not active. Â I have some suggestion for this and step by step procedure:
For Window XP
*From the start menu, choose Control panel.
*Open the Internet Options control panel.
*click the connections tab.
*click the LAN settings button.
*Select the "automatically detect settings" checkbox.
*click OK in both windows.
*Reopen itunes and connect your iphone, ipad, or ipod.
*Update or restore your device.
FOR Windows VISTA and Windows 7
*From the start menu, choose control panel
*select network and internet and select internet options. Or in classic view, open the internet options control panel.
*select the automatically detect settings checkbox.
*click ok in both windows.
*reopen itunes and connect your iphone, ipad, or ipod.
*update or restore your device.
I hope it will help you to solve this issue.
