Stevenwhite
10 points
Posted on - 07/25/2011
I am using a Win XP Professional SP3 machine from past one year. Installed iTunes and have been successfully able to transfer songs, videos , games and other free apps.
I heard about this interesting iPodifier which would capture the contents from any source like a TV or any other media and would put it on my iPod. This would allow me to watch my favorite series later even if I missed it . I have a version 1.5 installed on my machine.
Recently when I was working with my iPodifier I tried to save one of my file and it came up with an error message.
“An error occurred while displaying the previous error”
It just keeps coming back in loop again and again when I click on OK.
Has anyone come across something like this. If so please help.
dirk01
5 points
IPodifier error message while saving
Hello Steven,
I Lolled for a second. Anyhow, that has something to do with your application, if it keeps looping around like that then, it might be a bug, try updating to the latest version. But if you don’t have it yet, your best chance is to have it freshly installed. Just uninstall it using the add/remove programs in control panel and reinstall it again using the installer. Also doing a Registry Cleanup would sometimes resolve the problem, there's a free one on the net just Google it up the best one is CCleaner.
I hope this helps your problem.
Regards.
Dear Stevenwhite,
Error message “An error occurred while displaying the previous error” is a funniest error message which I never seen before and nor heart before. After web research and reading some forums, here are my some suggestions / solution for you.
Complete uninstall your iPodifier 1.5 and delete the folders that contains iPodifier files.
Install Registry Cleaner software and clean all your registry entries.
Download latest version of iPodifier 1.504 from: iPodifier latest version.
In latest version, lots of little problems and bugs have been fixed.
Hope it will work and above mentioned error will not display again.
Stephy
