Hi there,
I have updated my MAC OS to Lion version and I have this error with some programs. iRise Studio is not the only soft that when I try to open I get this error. I don’t know what is happening after this update, but there are a lot of errors. Can anyone tell me if I should install my previous version ? This errors can be solved ?
Thank you !
iRise Studio Is damaged and can’t be opened. You should move it to the Trash.
Safari downloaded this file today at 12:14 PM from esd.subscribenet.com.
Cancel Move to Trash
iRise Studio shows error when trying to open
If you are using Mac OS X 10.7 Lion on your Macintosh, I don’t see any problem why it displays an error because your operating system is fully supported. If we’re going to check the software’s requirement for the hardware part, I don’t see any problem either because iRise Studio doesn’t require a high specification.
The application can run even on Pentium 4 1 GHz processor putting it compatible on slow computers. iRise Studio supports Windows Server 2003 Service Pack 2, Windows Server 2008 R2, Windows XP Service Pack 3, Windows Vista Service Pack 2, Windows 7, and Windows 8. iRise Studio 8.11 and later is required if you have Windows 8.
For Mac users, it supports Mac OS X 10.6 Snow Leopard, 10.7 Lion, and 10.8 Mountain Lion. iRise Studio 8.11 and higher is also required if you have Mac OS X 10.8 Mountain Lion. For the web browser, you can use Mozilla Firefox 3.5, Microsoft Internet Explorer [7, 8, or 9]. Apple Safari 4 is supported in Windows. For Mac, Apple Safari 5 and Google Chrome 10 are supported. Google Chrome 8 is supported on Windows.
Since we cannot determine that it is incompatibility that causes the error, I think the reason is downloading the software from a different website rather than from the official website. Downloading from other sources doesn’t guarantee of the quality of the software and you are not sure if it is damaged or not. Try downloading it again from the official website, iRise Studio.
