Is 3d Acceleration Windows 10 Simple To Use?
Hi, I wanted to know how to use 3d acceleration windows 10 for my PC inside a virtual machine? Please help me?
A) To use 3d acceleration windows 10 virtual machine, you will need to follow these steps:-
1. Open your virtual machine like a virtual box, then click on the Machine menu > Settings > Display.
2. Inside the display, option-click on the enable 3D Acceleration option to enable it. And now, it will work inside your virtual machine.
B) To use 3d acceleration windows 10 virtual machine, you will need to follow these steps:-
1. Open your virtual machine like VMware virtual box, then click on the Machine menu > Settings > Hardware> Display.
2. Inside the display, option-click on the enable 3D Acceleration option under3D graphics to enable it. And now, it will work inside your virtual machine.
