Is Account Disabled Windows 10error Be Solved?
A) To rectify the “account disabled windows 10; you will need to follow these steps:-
1. Hit the Windows menu key and the R key altogether to open the Run dialog box. Write down lusrmgr.msc inside the Run dialog and press the Enter key.
2. Now, go to Users > Administrator and right click and go to its Properties.
3. Inside the General tab, settings untick an Account is a disabled option. Now press the ok button.
B) To rectify the “account disabled windows 10; you will need to follow these steps:-
1) Press and keep holding the Shift key and press the Power button located there.
2) Inside the Advanced Recovery Options > Advanced Options > Command Prompt.
3) Inside the Command Prompt, write down the following command and execute it:
net user administrator /active:yes
4) Now, reboot your PC.
Notifications
