Is Conexant High Definition Audio Is Useful?
What is Conexant high definition audio? What is its importance, and how can I install it? What is the current version running in the market?
It is a software owned by “Conexant systems.” The Conexant high definition audio is a chipset to process audio. It is saved in your computer as “cAudioFilterAgent.exe” which helps in to run the driver associated with the chipset. It process the digital signals, already comes preinstalled on your computer. It helps provide audio output for software programs. It supports the Windows platform.
This is a .exe program that is an executable file that may cause harm to the computer. It is not essential for windows and often causes issues. I request you to remove this file instantly as it records the keyboard and mouse inputs. Its technical security is 30% dangerous. This file is located in “C\Program files(x86) \ CONEXANT\cAudioFilterAgent.exe”.
Notifications
