I was taken aback when I saw this error code 0x80016cfa pop-up from nowhere while browsing. I thought it would away if I closed and reopened my browser again. However, that did not happen, and every time it shows up, I have to close the browser forcefully. Is this error a real one? Please assist me in solving it.
Is Error Code 0x80016cfa Real Or A Scam?
Hi, do not make any call on that number as this error is not real. Off late, there have been a lot of awareness campaigns online, to make people aware of these technical scams. In this fraud, the error message urges people to make a phone call as early as possible to get rid of the error. Hence, PLEASE BEWARE of these scams and do not give them anything.
To get rid of the malware, the following steps will prove to be beneficial:
• Trying to exit the browser will not be of help since these errors will not easily let you do so. Hence, open the Task Manager.
• Go to the Processes button and right-click on the web browser you are unable to close and choose End Process option. In some of the scenarios, you might wish to choose End Process Tree option.
• Doing the above step will kill the error script and clean your browser. You can try opening it again and reset the web browser. However, do not choose Restore session option as it will bring back the error.
• You can also check your PC for any malware by running Anti-Malware software to get rid of residues of the error.
Error code “0x80016CFA” is one of the many tech support scams related to Windows Defender. This scam tends to use Microsoft Edge web browsers and targets computers running on Microsoft Windows 10 but is not limited to Windows 10 only. It normally appears on the system several days after downloading third-party software like media player, download manager, or PDF converter.
This fake alert is triggered by ad-supported plug-ins that spread as third-party software attachments. When this fake alert pops up, it takes a full screen of the web browser and freezes it so you cannot exit the blue screen environment by pressing the “X” button or the “OK” button. The message contains several bug check values like 0x80060402, 0x0000007B, and 0x80060402.
Aside from that, it includes the “INACCESSIBLE_BOOT_DEVICE” BSOD error name and “dllRegisterSetting” file name. This technical information refers to the existing Windows bugs that’s why entering any of these codes in Google search will give you enough amount of information. If a user gets caught in the trap, scammers give the number of a certain “Windows-certified technician”. Here’s where the danger lies.
The number given doesn’t belong to any IT specialists, at least not for the trusted ones. This scam tries to swindle people’s money or trick them into giving full control of their computers remotely. If you started receiving error code “0x80016CFA” and it provides you with a telephone number to call, don’t you ever try to call it. Update your antivirus and perform a full system scan.
You can also use Sophos Virus Removal Tool to scan your computer. Try also to uninstall and reinstall your browsers.
