Is Firebase A Database
What is Firebase used for and what is firebase in Android? Is firebase a database can I use it for my project to store contents in it? What can be different firebase authentications?
Firebase is used as your app’s backend, which will include data storage, user authentication, hosting, and many more. It gives a real-time database as its service. The service presents developers an API that allows application data to be in synchronization and stored on firebase’s cloud. It is the assistant tool window in android studio. Firebase is a mobile platform that helps in the development of high-quality mobile apps.
Firebase real-time database is a cloud-hosted database. Data is stored in JSON format and is synchronized in real time. Yes, you can use it in your project to store contents as it will allow you to access that content dynamically in your app.
Firebase is simple to use with no need for complicated configuration. As the data in real time, which means that every change will automatically update. One limitation of firebase is that the free plan is limited to 50 connections and 100 MB of storage.
There is various firebase authentication such as email authentication, Google authentication, Facebook authentication, Twitter authentication, Github authentication, etc.
Notifications
