Hi, I am a student, and I wanted to put up data and save it on a server so that all my co-members could access that and I could access theirs. I wanted to create a server and install it so that I can work on it. Would you help me in windows server 2008 installation
Is It Easy For Us To Install Windows Server 2008 In Our System
It is easy to install windows server 2008 in your system and create your server. There are a few simple steps which are similar to the installation of windows vista, and your server will install in just a few minutes.
A) Firstly, insert the appropriate windows server 2008 installation media either through DVD drive or by downloading it from the website. Then, reboot your system.
B) Make your particular selection for the language when asked for and press next. Then, press installs now option to start the installation process.
C) If you have any product id and product key, then fill it and tap next but if you are not having one, then leave it empty and click no, but fill the id later as it is required.
D) If you provide the correct product ID and product key then, select the full version and tap next. Read and choose the license agreements when asked for and then tap next.
E) Select the type of installation as custom and then select the disk where you want to install. Then, your product will install.
