Is Shielding Important Between Phone And App Data?
The total data of a user has resided on their phones. Any malware in my app will lead to the problem of entire data on the phone. So how can I secure the phone through the app? The security of my app is the security of total data on the mobile.
Answered By 0 points N/A #319507
The mobile operating system and mobile device management provide the primary level of security to mobile. Allowing your app only to use the decided memory will also secure the phones. That is the app wrapping your applications. Using a single sign-on will also protect the mobile through your app. API and data must be very secure, so you need to know who is using your app and where. The security should be started building at the operating system level is more useful. Apple provides a good job enforcing security and creates rules on whether or not to install the app.
