Is There A Bitdefender Uninstall Tool For Windows?
I earlier used to use the Bitdefender software for my computer. Now I want to uninstall it. But I am not able to uninstall it. How can I uninstall Bitdefender using the Bitdefender uninstall tool?
Yes, if you can’t install the software manually, there are Bitdefender tools that can help you to completely uninstall the Bitdefender software from your computer.
Visit the URL http://www.bitdefender.com/uninstall/ and select the product type you want to uninstall.You can select the consumer product or the business product in the paid and trial version.
After you select the appropriate option, you can see a webpage where you will get download links for tools which can use to remove the Bitdefender software from your computer completely.
Notifications
