Is There A Way To Solve 3rd Monitor Unable To Save Display Settings Error?
Hey, I was facing 3rd monitor unable to save display settings error with my monitor. Is there a way to solve this aroused issue?
A) To solve this aroused issue of 3rd monitor unable to save display settings error, follow these steps:-
1. Press and hold the Window key and the R key to open the run dialog box window.
2. Inside the Run dialog box window, write down Regedit and then press the OK key.
3. Find the following registry subkey:
KEY_CURRENT_USER>Software>Microsoft>MobilePC>TMM
4. Right-click the subkey that you found and Delete it.
5. Confirm deleting it by pressing the Yes button.
6. Now, in the File menu, press the Exit and then restart your computer. It will solve it.
B) To solve this aroused issue of 3rd monitor unable to save display settings, you will need to follow these steps:-
1. Open Screen Resolution by pressing on the Start menu > Control Panel > Appearance and Personalization > Adjust screen resolution.
2. Tap on the drop-down list near the Multiple displays > Extend these displays > OK.
