Is There A Way To Solve This 0x02 Error?
A) 0x02 error happens when ImgBurn fails or crashes while running, hence its name. It does not mean that the code is corrupted, but it did not work during its run-time. To fix it,
• Type Control Panel on the search box of the start menu of your version of windows and choose the result, then click Uninstall a program
• Once inside Programs and Features, click on the program and choose Update or Uninstall.
• When you need to follow the prompt to complete the process, however, if you choose to Uninstall, you will follow the prompt to uninstall and then re-download or use the application’s installation disk to reinstall the program.
B) To fix this 0x02 error, you need to make sure you update your virus program and run a thorough scan of the computer or run Windows update so you can get the latest virus definition and fix. As a virus infection may be causing your runtime error on your computer system must immediately be prevented, quarantined, or deleted.
