king garcia
Posted on - 12/15/2020
I started my PC today and found my Acer Aspire laptop keyboard locked. I am unable to use my keyboard as hitting the keys does not respond. I have restarted the device several times, but it did not help. I use a Windows 10 OS. Is there any fix?
Is There Any Acer Aspire Laptop Keyboard Locked Fix?
You can try the following methods to fix your issue – Acer Aspire laptop keyboard locked.
Method 1
a. Open Settings.
b. Go to Ease of Access.
c. Go to the Keyboard tab.
d. Turn off Filter Keys.
e. Try to operate your keyboard.
Method 2
a. Right-click on the start menu.
b. Open Device Manager.
c. Right-click on Keyboards.
d. Click on Scan for hardware changes.
e. Follow the on-screen instructions.
f. After the process completes, your keyboard should work.
