Is There Any Method To Fix The 0x8024a10a Error Code In Windows 10?
There was some problem while updating Windows 10. My Windows 10 updates automatically, but the last time, it shows 0x8024a10a error code. Please help me.
There are a few ways that can be helpful to fix the 0x8024a10a error code.
Method 1
a. Press Windows + R using the keyboard.
b. Type netplwiz, and hit enter.
c. Select the user, and go to properties.
d. Go to the Group Membership tab.
e. Select the Administrator, and save the changes.
f. Restart your device.
g. Using the same account, update windows.
Method 2
a. Go to the following link
b. Download the zip file.
c. Extract the tool from the file.
d. Right-click on it, and run as administrator.
e. Type Yes, and press enter.
f. Complete the process.
g. You will be able to update the windows.
