Is There Any Microsoft Word 2013 Update Available
I am facing some issues in my Microsoft Office 2013. and I am not able to identify them. May be any update can help. Is there any Microsoft Office 2013 update available?
You can find the update in your system if you have installed Microsoft Office 20013 correctly. Another option is to download the update online. Just google Microsoft office 2013 update and you will get the required updates and the available updates for Microsoft Office 2013. Most of the times, the updates for Microsoft office come over your windows only as soon as they are released by Microsoft. If you missed them out, then you can download the update from the web.
If you have Microsoft Office 2013 and you want to update, you can update to Service Pack 1. To download the update, download one of the following:
Note: if you have 64-bit Microsoft Windows and you installed the 32-bit version of Microsoft Office 2013, you should install the 32-bit version of Microsoft Office 2013 Service Pack 1. You need to restart the computer after installing the update.
On the other hand, if you have the “Click-to-Run” version of Microsoft Office 2013, you’ll be prompted to update automatically to Service Pack 1 and there’s no need to download the update listed above.
