milodiaz
10 points
Posted on - 01/23/2017
Usually it is known that there is no backup plan available for Windows. But, it isn’t correct; there areways to Windows 7 restore the files individually from backup, do you want to know about it?
Is There Any Possibility For Windows 7 Restore Files From Backupplan
Most of the people don’t know about this backup process in Windows. But luckily, the backup panel can create the contents of full system image and can also certainly browse and extract the individual files.
If you are accessing the Windows 7 restore documents from backup then it means that you are provided to restore the entire system. By this it is your choice whether you are restoring the system entirely or particular files that are important. For mounting the system image, the Disk Management application should be opened and in the VHD the files can be saved. The system images stored can be retrieved from the same file location.
