Is There Any Possible Way Of Correcting The 0x9c Machine_check_exception Error?
Hey, I was stuck with this 0x9c machine_check_exception error inside my PC. Can anyone help to rectify this 0x9c machine_check_exception error?
A) This 0x9c machine_check_exception error caused many reasons like some hardware issues like ram not working properly, driver issues, corruption, and so on. To fix the 0x9c machine_check_exception error, you will need to the Memory Diagnostic Tool by following these steps:-
1. Hit the Windows key and R key altogether, then write down mdsched.exe, and then hit the enter key.
2. Now it will open Memory Diagnostic Tool and then choose the option that says, “Restart now and check for problems (recommended).”
3. The system will restart and check for the memory problem.
B) To fix the 0x9c machine_check_exception error, you will need to update your windows with the latest updates for your PC.
Notifications
