Is There Any Possible Way To Rule Out The 0x803fa067 Error?
I am unable to upgrade to the Windows pro edition. I have tried the troubleshooter and different ways of activating Windows. Is there any possible way to rule out the 0x803fa067 error?
Microsoft was quiet on the 0x803fa067 error. However, there is one possible way.
a. Open Settings.
b. Go to Update & Security.
c. Under Activation, click on the Change Product key.
d. Enter VK7JG-NPHTM-C97JM-9MPGT-3V66T as the product key
e. Click on Next.
f. Right-click on WIfi/ Ethernet symbol on the taskbar.
g. Open Network & Internet settings
h. Click on Change Adapter Option.
i. Right-click on the Ethernet/ Wi-fi option.
j. Click on Disable.
k. Start your upgrade, and you will be successful.
