Is There Any Solution To 0x800f082f Error In Windows 10?
I am unable to solve the 0x800f082f error in Windows 10. I have tried all the suggested solutions such as Resetting the device, restarting windows update services, etc., but I cannot solve it. Is there any solution to the 0x800f082f error in Windows 10?
Answered By 0 points N/A #343689
0x800f082f error in Windows 10 is a difficult error to solve. There is only one effective workaround to solve the 0x800f082f error.
a. Press Windows + R.
b. Type Regedit, and press enter.
c. Click Yes, if you get a prompt.
d. Go to –
KEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\SessionsPending.
e. Double-click on Exclusive.
f. Change Value data to 00000000.
g. Click on, OK.
h. Double-click on TotalSessionPhases.
i. Change the value data to 00000000.
j. Click on, OK.
k. Restart your device.
The above method will solve your issue.
