Is There Any Way To Fix – A Password Is Required To Synchronize This Notebook Error Code?
The following methods can help you fix – a password is required to synchronize this notebook error code in OneNote.
Method 1
1. Close all the apps on your PC.
2. Press Windows + R.
3. Type Credential Manager and press Enter.
4. Go to the Windows Credentials tab.
5. Find out the following cache labels MicrosoftOffice15_Data: or MicrosoftOffice16_Data:
6. Click on Remove.
7. Open OneNote and do your work. Provide the credentials if asked.
Method 2
1. Open OneNote.
2. Click on your name initials on the top corner.
3. Click on Sign Out.
4. At the Remove Account prompt, click on Yes.
5. Restart OneNote
6. Click on Sign In.
7. Enter your credentials.
8. You will not get the error after this.
