Is There Any Way To Fix The 0xc0000142 Error In Windows 10?
The 0xc0000142 error pops up when I install a game and open it Windows 10. I do not understand how to solve the error. Is there any way to fix it?
The 0xc0000142 occurs due to corrupt or missing files. Here are a few fixes for you.
Method 1
a. Press Windows + R on your keyboard.
b. Type Regedit and press enter.
c. Open HKEY_LOCAL_MACHINE, then SOFTWARE, then Microsoft, then Windows NT, then CurrentVersion, then Windows.
d. On the right pane, double-click on LoadAppInit_Dll.
e. Change Value data to 0.
f. Save the changes.
g. Restart your device.
h. Launch the game.
Method 2
b. Type cmd and press CTRL + SHIFT + ENTER.
c. Type for %i in (%windir%\system32\*.ocx) do regsvr32.exe /s %i, and press enter.
d. Restart your device after the process completes.
e. Launch the game.
