Is There Any Way To Fix The 1935 Error Code When Installing Office 2016?
Is there any way to fix the 1935 error code when installing Office 2016? I have a Windows 10 PC with .NET Framework. I am unable to figure out the issue. Please help.
Microsoft recommends to repair your .NET framework to fix the 1935 error code.
Method 1
a. Press Windows + R on your keyboard.
b. Type appwiz.cpl and press enter.
c. Select Microsoft .Net Framework.
d. Click on Uninstall/ Change.
e. Click on Continue.
f. Select the Repair option.
g. Click on Continue.
h. Wait for the process to complete.
i. Restart your device.
j. Run the installer.
You can try the following methods too.
Method 2
a. Open Command Prompt as admin.
b. Type fsutil resource setautoreset true C:\ and press enter.
c. Restart your device.
d. Try to install your software.
Method 3
a. Press Windows + R.
b. Type Regedit and press enter.
c. Click on Yes when a window appears.
d. Navigate to – HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control.
e. Double-click on RegistrySizeLimit.
f. Set DWORD value to ‘ffffffff.’
g. Select the base as Hexadecimal.
h. Click on the Decimal button.
i. Enter 4294967295.
j. Save the changes.
k. Restart the computer.
l. Try to install the software.
