Is There Any Way To Fix The 40000015 Error In Windows 10?
The 40000015 error is a common error experienced by Windows 10 users.
Method 1
a. Press Windows + R on your keyboard.
b. Type cmd and press ctrl + shift + enter on your keyboard.
c. Type sfc /scannow and press enter.
d. Complete the process.
e. Restart your device.
Method 2
a. Open Settings.
b. Go to Update and security.
c. Go to Windows Update from the left pane.
d. Click on Check for updates.
e. Let the download complete.
f. Restart your device.
Others –
a. Installing a new application from an untrusted source can cause this error. If you have done so, please uninstall it and check.
b. If you are using a third-party antivirus, please update the software. Open your anti-virus application, and there you will find an update option under one menu.
