I am using a Windows 10 PC and Office 2010. All the Office apps are working properly, except for Excel. Excel suddenly crashes while working with an exception code – 0xc0000005. I have updated the app and ran the troubleshooter, but it did not help. Is there any way to solve the 0xc0000005 Excel issue?
Is There Any Way To Solve The 0xc0000005 Excel Error?
I do not know the exact reasons behind the occurrence of the 0xc0000005 Excel error, but various methods can help you –
Method 1
a. Press Windows + R.
b. Type %appdata%\Microsoft\Excel\ and press enter.
c. Cut all the folders present inside the Excel folder and save it somewhere else.
d. Make sure the Excel folder is empty.
e. Work with Excel.
Method 2
a. Press Windows + R on your keyboard.
b. Type excel /safe and press enter.
c. If the application works well, the error is caused by add-ins.
d. You need to start to excel in normal mode and disable add-ins one by one to determine the culprit. If you do not need add-in, disable all.
Method 3
a. Open Excel.
b. Go to File -> Options.
c. Go to the Advanced tab.
d. Untick the Ignore Other applications that use Dynamic Data Exchange (DDE) option.
e. Restart Excel.
