Is There Any ZoneAlarm Removal Tool For Windows 10?
I want to remove ZoneAlarm from my Windows 10 PC. Is there any ZoneAlarm removal tool for Windows 10?
You will not find any official ZoneAlarm removal tool for Windows 10. Follow these steps to remove ZoneAlarm from your system.
a. Open the ZoneAlarm Security program from the start menu.
b. Click on the Tools dropdown.
c. Select Preferences.
d. Untick the “Load ZoneAlarm at startup” option.
e. Click on OK.
f. Close ZoneAlarm.
g. Reboot your computer.
h. Press Windows + R on your computer.
i. Type appwiz.cpl and press enter.
j. Find ZoneAlarm in the list of programs.
k. Select ZoneAlarm.
l. Click on uninstall
m. Click on Yes when prompted.
n. Your computer will restart.
o. Now, you will not find any traces of ZoneAlarm.
