New software by Microsoft was released a few years ago. As Windows are very-very interesting thing for lovers of software line, Windows 7 Registry Cleaner Microsoft gave an equal thirst. Did it work as promising or is it alright to make use of it?
Unfortunately, there wasn’t much good response from people after using it. After using the Windows 7 Registry Cleaner Microsoft, it was noticed that it has no much effect on the system’s speed due to its size.
You can better leave it alone as the registry cleaning is not required or won’t take place so seriously. Despite, people may think that it is fairly convincing but doesn’t work in reality as desired. Still if you want to use any cleaner, you can try c-cleaner which is known very good and can use it for free as Windows 7 doesn’t contain any registry cleaner software of its own.
If you are looking for an application that can clean your Windows registry or simply a registry cleaner, PC Tools is a great choice. Download PC Tools Performance Toolkit and follow the instructions to download and unpack the file. This is the latest and last version of PC Tools after its company was acquired by Symantec and was later dissolved.
It supports Windows XP, Windows Vista, Windows 7, and Windows 8.x. Microsoft Windows 10 is not officially supported but you can try and see if it works. PC Tools requires Intel Pentium IV or equivalent processor, 512 MB RAM, and 100 MB hard drive space. Now to clean your Windows registry, start PC Tools then go to “Performance” tab and click “Clean Your Registry”.
PC Tools registry cleaner
On the next screen, make sure “Complete Registry Scan” is selected under “Select the Type of Scan to Run” and then click “Start Scan” to begin checking your registry.
PC Tools scan the registry
Wait until PC Tools completes the scan. When it is finished, click “Repair”. This will clean your registry by deleting invalid or missing registry keys.
PC Tools start cleaning
Once the registry cleaner is finished with the repairs, go back to “Performance” tab and click “Compact Your Registry” to defragment the Windows registry and optimize the performance. It is important to defragment the registry to improve application loading time.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
