Is Your Zoom Audio Not Working On The Computer? Simple Solution Found?
Hi, Guys! Recently, I downloaded the zoom app, and when I made my first call, I realized zoom audio not working on the computer. Is there a way to fix it?
A) Well, zoom audio not working on the computer caused due to your speaker might have break or volume turned off.
To fix it, you can try to turn on your volume by pressing the volume icon and then dragging the volume up as much as you prefer. And if it has broken, you need to get it repaired or might need to buy a new one.
B) Well, zoom audio not working on the computer could also be caused due to, when you had not connected or configured the microphone properly result, you might be to hear others, but they are unable to hear you.
To fix it, you can try to check the microphone connection at your pc, or you can check the configuration of your microphone inside your computer by checking that the wires are connected to their respective places.
