ISO image file of cd-rom
Hello everyone. How are you all?
I want to know something. Can we create ISO image file of cd-rom, which we have install OS!? Can you give some link about this.
Please, tell. Thanks in advance.
ISO is a universal image file system that comes with many features. Any CD/DVD can be turned into ISO, and the ISO can be used for any purpose and even for installing OS from the USB!
In order to have the awesome feature of ISO, you have to get any ISO software. There are many free tools and paid tools for this purpose. Some of the best free tools are ISO Workshop, Burnaware Free etc. There are also other tools like UltraISO, PowerISO, MagicISO etc.
After getting any of the software, you can create any ISO of any sort of CD/DVD’s image. But you have to be sure that the CD/DVD’s data is completely okay. If the data from the CD/DVD is corrupted, the ISO will also contain corrupted data and will give you lots of pain.
You can create bootable USB drive to install OSs from the created ISO or other downloaded ISO. You can use WiNToBootic, Rufus etc.
