Issue with CD Playing Software
Recently, I have installed Windows 7 Enterprise edition on several computers. I have a particular kind of software for school. It is required to be run on a single computer system though I start it, it results in “Page not found”. However, the next day when I execute it, it works fine but for the very other next day, it raises the same error once again.
Regardless of this issue, when I tried it on other computer system, it can’t even execute the program and results an error message saying “Class not registered”.
Answered By 0 points N/A #154852
Your software is likely a single user, meaning it can't be installed into another computer once installed. The reason you maybe having difficulty is, you installed on one computer but didn't register it properly, so you installed on another PC & so on. Until you register it properly it will keep giving you errors & soon it won't work because you have installed on more than one PC.
I would advice you to get a genuine software that's multiple user enabled, meaning you can install in many PCs without having glitches. After that you ensure you have registered it online to get the genuine product key that will be used always whenever you are installing on a new PC.
Hope that helps.
