Issue in declaring macro in excel
How can i declare a macro in excel spreadsheet? I am facing problem while declaring it, because of it's wizard. Tell me an easy way. thanks in advance
Hi
It is very easy to declare the macro in Microsoft excel so just go to the line bar at the top of the excel and before going to write anything first go the view bar and find the setting and in the setting select the macro it will select the macro and after that come to the line bar at the top of the excel and then write whatever you want it will write in macro level and this is very easy to do so. Hope this solution will help you in finding the how to tackle with macro in excel and how to work in it and how to activate the Macro in excel so try this one and you will work in macro in excel.
Hi Ricky ,
The following is the way that you are able to display macro in excel spread sheet
a) Go to the new worksheet
b) On the windows option go to Excel option. It will take you to a place where there is change most popular application in excel
c) There at the top you will be able to see the following
Show mini toolbar on the selection
Enable live pre view
Show the developer tab in the ribbon.
d)Choose the option of show the developer tab in the region
The developer tab will appear
At the developer ribbon you may be able to perform various tasks
