Issue with eclipse rdf editor
I am using eclipse rdf editor. I have installed Eclipse 3.5.2 in my system. I want to know that, Is there any log to find out about issues while running RSSOwl? Please tell me if it is possible and how to do this.
Answered By 5 points N/A #148426
Here is how you can find log file about issues while running RSSOwl:
1. If you have Windows XP on the hard disk drive C go to Documents and Settings, open the folder with name of your computer, then open .rssowl2, here you can find .metadata and open it. Finally here you have log file .log
2. If you use Windows 7 open C->Users->name of your computer->.rssowl2->.metadata->.log
Other way you can find log file is in Help->Export Logfile.
If you want to know more about solving issues while running RSSOwl go to this link: https://github.com/rssowl/RSSOwl
Hope this will help!
