Issue with Folder view options in Windows 7
Hi all,
I am using Lenovo Thinkpad T410 wit Windows 7 pre-installed in it.
It is working fine, but I have one problem recently. I have several folders with files, photos, videos, music, etc., I would like to set the folder options differently for each folder. For example, for the folder where I have documents I want to set the folder view options to Details so that it will show all details and in the folder where I have photos I want to put view option to Thumbnails and so on. But, the issue is that when I change the view options for a particular folder, it is propagating that to all other folders as well. So, I am not able to achieve my need.
Is it possible in Windows 7 or not? If possible, How can I make it work? Please advise. Thanks in advance!
