Issue with halts in streaming video by my NVIDIA GTX 670
Whenever i play video in my firefox browser, the streaming video halts. I have a high speed internet connection, so no, its not my broadband. Is this problem related to my NVIDIA GTX 670?Â
I think your computer is having a problem streaming any videos using your present version of Adobe Flash Player. The smoothness of the videos streamed on your web browser relies on the installed Adobe Flash Player of your computer.
This problem is usually caused by older if not outdated version of Adobe Flash Player. Check again the current version of Adobe Flash Player installed on your computer using the Add or Remove Programs applet of Windows. Click Start then Control Panel.
Click on Add or Remove Programs then find and select Adobe Flash Player to highlight it. Next, click on Click here for support information. On the next window you will find the Flash Player’s version.
Check if you are using the latest version. As of now, as I check Adobe’s website, the latest version is Adobe Flash Player 11.3.300.262. Check your Flash Player’s version if you are using this one.
If not and you are still using an old version, update it to the latest version. I think this is the main reason why you are having problems watching streaming videos on your web browser. To download Adobe Flash Player 11.3.300.262, you may visit Adobe — Adobe Flash Player — Adobe Flash Player 11.3.300.262.
