Young Hern
10 points
Posted on - 02/12/2013
Hello Techyv Friends,
I installed HASP driver successfully in my Win7 32bit and is supporting fine. But when I tried the same in Win7 64bit, It says it installed successfully but it doesn't see the HASP device, Is there any issue with HASP for Win7 64bit. Please guide me to overcome this issue.
Thanks,
Young Hern
Issue with HASP for Win7 64bit
Hi Young
Yes, there are compatibility issues between HASP and Windows 7 64 bit Operating System. I would also like to inform you that the last updated version of Hasp edit was released in 2002. There is no newer release of Haspedit up until now. In general it is strongly suggested to move at some point to the new protection of Sentinel HASP. You can still use Hasp4 of course but for the developer tools you should use systems up to 32bit Operating systems.
'HASP Edit' is not supported on " Win7 x64 machine."
Note: 'HASP Edit (32bit)' may work or may not also work on Windows 7 (32bit) Run the “HASP 4 driver” above will tell you our OS is not supported but it may continue to install the driver as well.
I hope this information helps.
