Issue Named As 0x8024500c Error Occurred While Installation Of The Updates
What is the 0x8024500c error? Why Windows Server Update Service gives out this error and explains the steps to resolve this error code.
0x8024500c error is a Windows update error when the user is trying to update a UWP app via the Windows Store. Third-party security interference, bad Windows update, corrupted Windows Store cache, interfering proxy, or VPN connection is the reasons for this error code. The methods to fix the 0x8024500c error code are as follows:
Method 1:
Try cleaning the Store Cache.
Step 1: Hold the Windows key+ R and open the Run dialog box.
Step 2: Type WSReset.exe and click on “OK.”
Method 2:
Run App Troubleshooter.
Method 3:
Disable Proxy Connection.
Step 1: Go to Gearbox at the top right corner in Internet Explorer.
Step 2: Go to Tools and click on Internet Options.
Step 3: In the Connection tab, click on LAN settings.
Step 4: Use a proxy server for the LAN checkbox.
Step 5: Click on, OK.
