Issue with one application built by developers using expression engine based website
Hello community,
Please refer to the following website:
Please note that it is an expression engine based website. I actually need your help in fixing an issue on this existing website. One of the developers I hired build 2 applications, which were running perfectly, but now, one of the applications has an issue and it needs to be solved as early as possible.
The application is actually a field scheduler for a soccer coach to log in and their required fields and timings for the practice session. When the soccer coach makes a selection, a report is automatically generated as a reference for the organization.
Now, we being on the admin side are facing some issues. After creating the fields successfully and adding in the timings for the coaches, I get an error. The screenshot is attached below:
A PHP Error was encountered
Severity: Notice
Message: Undefined index: day2
Filename: controllers/fieldadministration.php
Line Number: 171
Severity: Warning
Message: Invalid argument supplied for each()
Line Number: 171
- time_field_id => 49
- time_subfield => Subfield 1
- time_segment => 3
- time_start => 3:00
- time_end => 4:00
Continue
As you can see Wednesday is highlighted in the screenshot. Actually it does not produce Wednesday on the next line, which makes it really awkward, and each entry has to be submitted one line at a time.
If anyone is interested in helping me, I'll be really grateful.
Moreover I can pay you for all your time and efforts you will use to help me out.
Loads of thanks.
Looking forward to your feedback.
Kindest regards.
