Issues with blue screen error (BSOD)
Hello everyone!
I suddenly got this blue screen upon turning on my pc. I have no idea why this occurred but even so I want it to get it fixed. What should I do? Can I do anything with this problem or I’ll have it repaired with a technician? What cause this to happen? Thank you for answering my questions.
Error:
If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to be sure you have adequate disk space. If a driver is identified in the stop message, disable the driver or check with the manufacturer for driver updates. Try changing video adapters.
Check with your hardware vendor for any BIOS updates. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode.
Technical information:
STOP: 0x0000007E (0xC0000005, 0xF88FF190, 0x0xF8975BA0, 0xF89758A0)
EPUSBDSK.sys — Address F88FF190 base at FF88FE000, datestamp 3b9f3248
Beginning dump of physical memory
