Hi!
When I Control click on some objects I still find the link to DevonThink sometimes. Then I uninstalled it and again re-installing it and then uninstalling again.
(Didn't screen grab last time it happened, nor note where, I know!)
Also I use AppZapper and AppCleaner.
Then I followed the website and uninstall instructions. But same things happened and still get the Devonthink link.
Need your suggestions.
Issues in DevonThink links pops out
Hi Carla,
 If you are using AppCleaner here's you can do, just click the AppCleaner and then hit the application tab you can see the list of  all application that installed on your computer and then just select the Devonthink and then click the search button and you can see all the files associated with the Devonthink and just select all of it and then delete. And there is another way also to delete a application using AppCleaner, just hit the uninstall tab and then open your application folder and just drag the Devonthink and delete it.  And that's it, for permanently deleted you can just go to Recycle bin and delete it.Â
I hope this will help.
Gothman Pil
