I have bought System32 xlive dll fallout three, but it is not working. It is not installing. I got the message that says live DLL is missing? I have never had this problem while downloading any other games. How can I fix this?
Issues In Operating System ‘System32 Xlive Dll Fallout 3’
This error usually arises as a result of some error in the Operating System Program or by some damages in the other program in the system. It is not related to an error in the game. You can remove this by downloading some antivirus file. You can download this file by this which will help you to download your game. You can double click on the package and choose “ Run as Administrator” once it gets installed you can restart the computer and try installing the game. If it still does not work, you can Run System file checked(SFC) scan and check if it solves your problem. SFC files help to remove all the corrupt and irrelevant files.
