Issues of incompatible tbb occurred
Intel® C++ Compiler and Intel® Array Building Blocks (Intel® ArBB) both install tbb.dll and tbb_debug.dll on the Windows* OS. I install Intel® C++ Compiler (either the stand-alone product or as part of, say, Intel® C++ Composer) and I have a system that already has Intel® ArBB, then I see this following "Entry Point Not Found", like this: Have any idea for resolution?
Error: The procedure entry point ?destroy@task_base@internal@interface5@tbb@@SAXAEAVtask@4@@z could not be located in the dynamic link library tbb.dll.
