I made a very nice Interactive Whiteboard (IWB) in PowerPoint. I added an automatic music background and I also inserted a STOP button that’s halts the display at any time you wish to end the presentation. Â
My problem is, even if I clicked on the stop button to stop the display, the music is playing simultaneously.
How can I fix it?
lee hung
75 points
Issues on inserting sounds and display using PowerPoint
Hello Benjamin,
Could you get a remote controller and try using it to control the sound options of the music you are playing in the background as opposed to pressing the button manually. Otherwise that you have embedded the sound features properly, the sound or music player that you are using does not have problems with the stop, pause and play buttons because this could be the possible cause to such a problem.
Another thing you could do is run the music differently without necessarily embedding it in the presentation, and make sure that it is in sync with each step of the presentation.
Regards
Lee Hung
